Licensing question
Just wanted to check that “2 profiles” means the alerts profiles, vs the user profiles in Vera? So if I want to use Prowl, Twilio and SMTP, I will need 2 licenses? I assume if I decide to then switch to using a different messaging profile, it is intelligent enough to know that I have deleted one and started using another?
It only counts used profiles since the last Vera restart.
You can define ten profiles.
But if you only use two …you only need one license.
If you want to change profiles …restart Vera.
