Hi All,
I just installed a number of Leviton VRS15-1LZ switches and VRMX1-1LZ dimmers. Some of them are stand-alone, while the others are a part of either a 3- or a 4-way. The setup was a breeze.
They are wired correctly. I’ve verified that all dimmers and switches (both masters and secondary/remote ones) can turn on/off and/or dim the load when operated manually.
I’ve also verified that they can be controlled from the Vera3/UI5 I have with no issues.
The problem is that when those switches/dimmers are operated manually, their status is not updated in Vera3’s UI… All masters (VRS15-1LZ and VRMX1-1LZ) are Vizia RF+, so they should support instant status (according to the Leviton manuals and support), however no matter how many times I switch or dim them, the status on Vera remains the same.
Any ideas are appreciated.
