I can’t seem to get the Vizia RF + to setup correctly in Vera. I keep getting a “setting special association” error on Vera web config page. I tried to see if it would work even if though I was getting the error and the RS232 commands would not work. Has anyone set one of these up successfully?
I forgot to put the model. The model of the Leviton unit is VRCOP-2LW. It is an RS232 interface module.
Welcome!
How far apart are Vera and the VRC0P?
It should work. Which Vera firmware are you using?
