leviton scene controller
i just added 4 new leviton dimmers today the new universal ones. i also added a 4 button scene controller.
the switches work fine from my unit on the webpage controller. iu5 I’m using. the scenes i created work fine too. my old scene controller works with my old scenes for the old dimmers in the house. the new scenes for the new dimmers are very wonky. some lights come on some don’t. the dimmer levels are off. the new scene controller won’t work the one scenes from the old dimmers and won’t control the new scenes for the new dimmers. i’m at a loss! i really need some help.
everythign from the net page works fine though. it’s the scene controllers that i’m having problems with. like i said the old scene controller will control old dimmer switch scenes no problem but not the new lights even. new scene controller is just not working properly at all
jim
Try adding a 1 second delay for all your Leviton scenes before executing any actions. I saw this tip on another thread and it helped with reliability. Doesn’t make sense but may help.
do i need to use triggers also though?
and can i still have on side of the button do an on command and the other die do an off command?
i can only get one button to work and only one side of it to work.
I’m on Ui5. I’m not sure how these work on newer UIs. It sounds like you’re using the zone controller with rocker switches, correct? You need to hook a scene up to each side of the device for each of the buttons. On UI5, you can go to the zone controller and the last tab on the far right is where you can configure the scenes. These devices can sometimes get into a weird state, when they are not behaving I also turn them off/on at the breaker.
I’m also on iu5. I am using the 4 button one with dimmer at bottom. The old way with old switches and scene controller was the way you say. The new ones you have to do triggers. The scene tab and the end of the wrench setup on the scene controller doesn’t work anymore. It does for old scene controllers and switche’s but not new ones. New ones need to be done with a scene with 1 sec delay then a trigger and link that trigger to a button. The other side of the scene button is the same scene but with a deactivate trigger.
My new problem is he dinner at bottom doesn’t work like it used it. Now it just doesn’t work!
