I’m pretty good with wiring but I’ve spend hours working on this.
I installed the VRI10-1LZ and the VP00R-1LX. The VRI10-1LZ works no problem. Turn on/off, dim up/down. The VP00R-1LX though is no joy. The dimmer LED lights up but it will not turn the light on or dim.
I know the remote dimmer needs to go on the line and I’ve swapped the positions multiple times just to make sure. I also tried two VP00R-1LX’s just to make sure I didn’t have a bad one.
I know people have struggled with these switches in the past. Anyone have the situation there the dimmer LED will light up but not work?
Does it need to be added to the Z-Wave network first or should the remote dimmer operate immediately after installation?
