I bought a Leviton DZS15 switch today on a whim as I wanted to be able to set my front lights to go on and off at certain times and control them through my Vera Lite controller. The instructions called for a four wire install for a single pole application which I found strange. The switch I replaced only had two wires (no ground, but the box appears grounded). So, I put these wires on the two top spots and did not attach a wire to the red terminal. The switch comes to life and I was able to pair it with my Vera Lite hub, but the front lights will not go on or off. Does anyone have any ideas? I have tried rewiring it several ways including putting one of the wires to the red terminal, but when I do that it will not come to life. I would think it is wired correctly since it has power and was able to pair with my hub. Perhaps I am using this wrong? Does it have to speak to a Z-Wave lamp and thus does not really have the ability to turn a regular light on and off? If that is the case, I just blew $50, but that was definitely not clear on the packaging.
Thanks,
Austin
