Hi everyone, I’m pretty new to the whole z-wave scene and have now run into an issue with the new Leviton DZ6HD dimmer. The installation and inclusion into Vera went without any issues. I am able to control the dimmer via app and web just fine. My issue is that its status isn’t being updated if manually pressed/dimmed. I’m very patient and have waited to see if it was just another round of polling needed, but it never updates.
I have tried manually polling via “Poll Now” under commands, but this times out. I also have a new Leviton DZ15S and have been comparing settings, and everything is the same. The DZ15S updates status nearly instantly and works flawlessly.
Any suggestions or troubleshooting steps? My system isn’t very big at all, 6 devices so far, all well within range of controller.
The new Leviton Decora line does not support Instant Status.
Only the more expensive Leviton Vizia RF+ supports Instant Status.
That being said the DZ6HD should eventually be update based on polling. Not sure why it is not. You might wait until the nightly heal to see if it gets better connected into your mesh.
This is a communications issue. Something is impeding the signal(range, obstruction, interference), or there is a bad route. The latter could be fixed by excluding(resetting) the device and including it anew.
My system isn't very big at all, 6 devices so far
An elevated risk of weak signal and poor mesh.
Unless the switch is 1 or 2 meters away from the controller, I would not make such a blanket statement. There are many possible reasons that the signal could be unable to reach what you assume to be the device's range.
I would suggest that you locate Vera and the switch 1 or 2 meters apart, exclude and include the switch, and then see if polling works. We can safely assume that Vera is good since other switches work with Vera. So, if this switch doesn’t work at this short distance, then your switch is likely bad. If it does work at short range, then you’ve proven that you have a signal issue to overcome. You can do this by, adding devices and improving the mesh, relocating devices to improve signal quality, eliminating obstacles and interference…
I have tried excluding/including, and resetting switch to defaults previously with no differing results.
I will check again this evening as it will have been over 24hrs since install. It just seems strange that it will work just fine when sending commands via the app or web, but not the other way around.
I will try moving Vera closer to make final determination this evening as well.
I’ve checked for status updates with Vera in original location: No Updates when physically used, Cannot Poll via “Poll Now” (Time Out).
Moved Vera within 3ft: No Updates when physically used, Cannot Poll via “Poll Now” (Time Out).
Bought a new switch, swapped it out, included just fine, can control via app/web perfectly: No updates when physically used, Cannot Poll via “Poll Now” (Time Out). I should add that Vera is still within 3ft
So what are the chances of having two bad switches…
What else can I do? I include it as a generic z-wave device and it is auto configured. What can I try and change to make it work?
I’ve also reached out to Leviton, but they have no immediate suggestions. My issue is being forwarded on.
[quote=“tameanaka, post:6, topic:195747”]So what are the chances of having two bad switches…
What else can I do? I include it as a generic z-wave device and it is auto configured. What can I try and change to make it work?[/quote]
The chance of two bad switches seems pretty slim. I don’t know what else you could do, your include procedure is correct. Regardless of status, you should be able to manually Poll Now. Assuming the switch is not bad, a timeout indicates a communication problem.
Another issue I’ve found…and PITA. The switch has a fade-on fade-off feature as well as memory of dimming level. When the virtual on/off switch is used on the app or web, the light comes on 100% and immediately. So no soft-on or off and loss of memory.
Physically these features work just fine. Not sure if this is something typical for Vera of just this particular switch.
I noticed as well, that both the DZ6HD and DZ15S don’t have any values for Neighbors when all my other devices do. Is that normal to not have any?
[quote=“shallowearth, post:2, topic:195747”]The new Leviton Decora line does not support Instant Status.
Only the more expensive Leviton Vizia RF+ supports Instant Status.[/quote]
Are there any available switches or dimmers that are Z-Wave Plus, and support Instant Status on Vera Plus? I think this does not exist.
There are some mixed reports in this thread that indicate the Homeseer HS-WD100+ might work with the Vera Plus with instant status. There is some discussion in that thread regarding the central scene for the single/double/triple tap (not likely to work with Vera) and the instant status (some say it works, others not). I don’t have a Vera Plus to test. http://forum.micasaverde.com/index.php/topic,37061.msg294336.html#msg294336
[b]"Thank you for bringing the issue with Vera to our attention. While we pair our devices with a number of Z-Wave hubs during testing we also rely on Z-Wave certification to ensure our devices will work correctly in the Z-Wave echo system. We are able to confirm that the Vera is not taking advantage of the 2-way capability in the device and is relying on polling.
We are now reaching out to Vera to review and work towards a quick resolution for future Vera releases.
Once again Thank You for your valuable feedback."[/b]
I have three of the DZ6HD dimmers with the same issue, no status updates when manually toggled, and cannot poll. I also have two DZ15S switches that work fine, relatively fast status updates and such.
I have the same issue with my two decora lamp dimmers (non rf+)they are just completely unreliable with Vera Plus compared to Wink/Wink2. Same drop off/and then I cannot communicate with the dimmer again, ever, until I delete device and repair.
side note: it’s funny to hear from Leviton on this Vera issue, hilarious. Never know what to really believe unless one is all knowing.
[quote=“tameanaka, post:11, topic:195747”]Received a response from Leviton:
Hope things get figured out sooner than later[/quote]
No, haven’t heard anything and I won’t. I followed up but it’s unfortunately in Leviton and Vera’s hands.
I was in contact with Vera and they basically said we can expect support “possibly” in two updates…first is at end of April. So in my limited experience I’d say July if we win the lottery.
Waiting for support isn’t my thing so I have since returned all my Leviton devices. When full support is finally available (probably 2018 lol) I’ll consider purchasing again.
[quote=“tameanaka, post:15, topic:195747”]No, haven’t heard anything and I won’t. I followed up but it’s unfortunately in Leviton and Vera’s hands.
Waiting for support isn’t my thing so I have since returned all my Leviton devices. When full support is finally available (probably 2018 lol) I’ll consider purchasing again.[/quote]
Hence, “if we win the lottery” lol. This is why I returned my two dimmers I bought. I still have the DZ15S as it “works”, but it doesn’t get neighbor node info…status is fine and is close enough to controller that I’m indifferent at this point.
FYI - it seems the most recent firmware update on my VeraPlus (1.7.2935) fixed the issue. My switch is now recognized whether it is on/off and regardless of how it was turned on/off (app or manually)
Does it register any neighbor nodes? I don’t have any of the dimmers anymore, but I have the DZ15S switch. It has always shown status, but the neighbors field has always been blank.
