Has anyone noticed that the Leviton dimmers might sort-of-kind-of have shortcuts for double-taps on the dimmer bar?
It’s a feature I really like on my older non-zwave electronic dimmers elsewhere in the house - double tap up to have the lighting go to full power.
Sometimes I seem to get the same effect “by accident” on the Leviton VRI-06 - I can double tap on the right or left of the dimmer bar to get the lighting to go to minimum or maximum brightness - but it’s really inconsistent, like if I try 10 times in a row it may only work 5-6 times. As far as I can tell this “feature” isn’t documented anywhere (and if it is an intentional feature it certainly doesn’t seem to work all that well ![]()
Has anyone noticed this, or even better can explain it?
