I picked up a $90 LED sign from these guys:
http://www.brightledsigns.com/products/4_x16_LED_Mini_Desk_Sign-12972-0.html
There’s a Perl library here for interacting with the sign:
I hooked up the USB sign to my XBMCbuntu box via USB and am displaying various pieces of info from Vera. It’s an XTreamer Ultra2 running XBMCBuntu 12.2.
Right now I’m streaming the outside temperature that is captured by my Netatmo.
Forgive the code, first time using Perl and not sure how to mark the area below as code
use Device::MiniLED;
use LWP::Simple;
my $sign=Device::MiniLED->new(devicetype => “sign”);
#Grab the outside temp from the Netatmo
my $url = ‘http://192.168.1.106:3480/data_request?id=variableget&DeviceNum=253&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature’;
my $content = get $url;
#Simple message
$sign->addMsg(
data => "Outside temp: " . $content ,
effect => “scroll”,
speed => 3
$sign->send(device => “/dev/ttyUSB0”);
I’d like to get this polished up and figure out how to insert the temperature symbol and basically run this every 10 minutes. Also will grab the forecasted highs and lows for the day - would be cool to have a symbol for the weather ( sun, clouds, rain, snow, etc) - it looks like you can do some drawing
Kind of cool for $90 though though having the USB connector on the bottom of the sign would have been nice or in the back for a clean install on the wall. Not sure if you can easily close open ports so that I can have the LED sign run on-demand (e.g. power on and power off)
