Has anyone had a successful upgrade to the new firmware using a Edge without calling support or going back to factory settings & doing a restore? Usually see a lot of postings that it worked fine. Not seeing this on this firmware version.
Since I upgraded I have had some very strange issues. Some remain unresolved.
For instance, I have TWO vera’s located in TWO different states. Scenes from one vera are appearing in my other vera. They don’t work on the vera they appear in but DO work on the vera they are belong to. In other words, I can trigger a scene on a different vera unit located in Colorado and have it execute on a vera box in Nebraska. ???/
How is this even possible? Not sure…and I am waiting on a response from tech support.
Thanks for info. I believe I will wait for a while before upgrading. I only use Edge for Foscam cameras & don’t want to be down trying to get them back up. All is working fine so guess don’t fix it if it an’t broke.
1.7.2935 is the latest.
It’s running fine on my VP
I.7.2931 is firmware version it wants to load on Edge. Guess it has to load that one first before you get newer versions.
I’ve upgraded my Edge. No issues at all.
Thanks trygve! Maybe server being too busy was why others were having problems.
Upgraded my Plus and haven’t had any issues. It’s been 2 weeks.
My issues have been resolved. No worries.
