Landscape lighing question
Hi all,
I have a 900W transformer that will eventually power my back yard landscape lights. Yes, it’s overkill, but it was $200 marked down to $50 (that day I got about 30 lights, the transformer and 100’ of cable for $250. It was a great day at lowes. All because they were changing the box design. Same products are there, different boxes and all LED lights to boot!). Anyways, it is actually 3 300w transformers and I’ve already planned out how I will use each branch (3 - 300w transformers, but 1 plug)
[ol][li]To left of the transformer (when facing it) and around the porch/patio (wire is already run for this branch).[/li]
[li]To the right of the transformer in flower beds (these go down the back of the house then from the house about 1/2 way to the back fence. maybe 50’)[/li]
[li]The Kids swingset/playset/fort thing.[/li][/ol]
#3 above is the part I am curious about. That day at lowes, the reason I ended up getting all those lights was because I thought it would be cool to put lights up and around the playset. In the Winter here in Florida, it can get dark around 5:30-6:00ish. If the kids don’t get home until 5, they don’t really get a chance to go outside and expend energy. I picked up a ton of spot lights, some wall washers and some path lights. The Path lights are for the front yard, the rest for the Playset and anywhere else I need them (I think I have 14+ spot lights… they were $3 each and all LED). I also plan to get more lights as I finish the design, but I picked up what I could that day (I wish I had picked up all of them to be honest).
So the problem is this. I want that thing to light up like a foot ball field, but only when the kids are using it. Since the transformer is only on and off (all or nothing), I can’t use it to control it unless I don’t want to use the landscape lighting as well. I was wondering if I could use some kind of relay to cut off the power to those lights when I’m not using it. I’m not scared to do anything, but my knowledge in this area is very lacking. It’s only 12-14v out, so I’m sure SOMETHING could be done, but I don’t know what.
Once I figure that out, I would need a device to connect it to the z-wave network. This could be as simple as using an arduino to control it and connecting it to the vera using the arduino project on the forums (which I plan to use for other devices/sensors as well). I’ve never done an arduino project either, so this will all be a learning phase for me.
Any help or even direction on where to look on to accomplish this would be greatly appreciated.
install a z wave outlet like the GE in the outlet where you plug in the transformer. Plug the transformer into the non-switched outlet.
Buy a 120 Volt relay, put it in a good box, power it with the Zwave outlet. Switch the wire (usually these transformers have a few posts) that runs the “sub-Circuit”
Very easy and all for the cost of a zwave outlet and a relay. Turn on the lights and add the sub circuit by switching the outlet
The thing to watch with low-voltage lights is that, although the voltage is low, the current is high. Your 300W transformer winding could deliver 25 amps at 12 volts. So a relay is a good idea but you will need one that will handle the current. It is important to remember that incandescent lamps draw a higher peak current when first turned on. For good reliability, use a relay that is rated at twice the normal running current. If all your lights are LED, this is less of a problem.
If your Z-Wave switch has isolated relay contacts (not tied to 115v), you could use an automotive relay with a 12v coil. Ones with 50 amp contacts are quite inexpensive. If your Z-Wave switch can only switch 115v, you will need to use a relay with a 115v coil and high-current contacts. It will cost more…
Thank you both for your replies.
@Bulldoglowell, My issue with using the z-wave outlet for the relay and just putting the landscape lights is that I want to currently control the whole transformer with the z-wave outlet and have a secondary controller/relay/switch for just the one circuit. That is why I was thinking of doing the Arduino solution, though after reading what @RexBeckett said, I’m curious if the the Arduino solution would be possible.
@RexBeckett, All my current lights are LEDs. I will more than likely just stick to LEDs. I already know the 900w is complete and total overkill for my applications, but like I said, it is 3 - 300w transformers so allows me to have 3 zones. According to the manufacturer it also only uses the power it uses, so I assume if I have a zone not on, that 300w transformer will not use any power (I assume there will be some, but very minimal).
I’ll have to do more research into the relay. My z-wave switch is only 115v, so I guess I will have to find the relay with both. My hope was that the arduino would allow me to keep it all LV in the box I’ll put it in and I can just plug it’s transformer into the non-z-wave controlled outlet on my z-wave receptacle. Could I use an Arduino with one of the “inexpensive” 50amp automotive relays you mentioned? (I’ve not had a chance to mess with Arduinos yet, but I have a list of projects I plan on using them for including RGB lights behind my bathroom mirrors, which have another thread on the forums)
[quote=“SirMeili, post:4, topic:180103”]Thank you both for your replies.
I’ll have to do more research into the relay. My z-wave switch is only 115v, so I guess I will have to find the relay with both. My hope was that the arduino would allow me to keep it all LV in the box I’ll put it in and I can just plug it’s transformer into the non-z-wave controlled outlet on my z-wave receptacle. Could I use an Arduino with one of the “inexpensive” 50amp automotive relays you mentioned? (I’ve not had a chance to mess with Arduinos yet, but I have a list of projects I plan on using them for including RGB lights behind my bathroom mirrors, which have another thread on the forums)[/quote]
you would plug an outdoor module into the un-switched outlet, and then plug your transformer into that. :wink: Use the switched outlet to power the transformer.
the problem with plugging in another device after the transformer is that you will disconnect when you power-off the transformer.
and… Rex has to debug his Ohm’s Law Lua routine
120VAC and 300Watts is less than 3 amps including line resistance at all your connectors.
[quote=“Bulldoglowell, post:5, topic:180103”][quote=“SirMeili, post:4, topic:180103”]Thank you both for your replies.
you would plug an outdoor module into the un-switched outlet, and then plug your transformer into that. :wink: Use the switched outlet to power the transformer.[/quote]
I’d have to change the whole outlet box out (not out of the realm of possibility). There is now way I’m fitting a transformer, a z-wave appliance module and the original plug into it. Does seem like the “easiest” solution.
Anyone have any clue on the parts I could buy (non z-wave parts that is)?
no, an outdoor module… it has a short power cable
http://store.homeseer.com/store/GE-45604-Z-Wave-Wireless-Lighting-Control-Outdoor-Module-P1319.aspx?gclid=CLjCr6v4ir0CFYc7Ogod7WkAFw
transformer plugs into outdoor module. Outdoor module goes into unswitched outlet. Relay goes into Switched outlet.
[quote=“Bulldoglowell, post:7, topic:180103”]no, an outdoor module… it has a short power cable
transformer plugs into outdoor module. Outdoor module goes into unswitched outlet. Relay goes into Switched outlet.[/quote]
Even with an outdoor module, I would rather have the transformer inside a box. two reasons:
[ol][li]Keep moisture from it and,[/li]
[li]Keep kids and animals from getting it. Currently all my outdoor boxes are lockable to keep the kids out.[/li][/ol]
yeah, its 120Volts, so you would have to mount a box alongside your outdoor outlet. So you need:
weather resistant outlet cover if you don’t have that already on the existing outlet
box, weatherproof for the relay
power cord from a heater, blender, old powerstrip or other high output device
transformer like this with nice connectors and you can mount it right to the back of the box.
http://www.newark.com/te-connectivity-potter-brumfield/t92p7a22-120/power-relay-dpst-no-120vac-30a/dp/17M3083?CMP=KNC-GPLA
I’m guessing less than $25 plus the extra zwave device.
@Bulldoglowell (or anyone),
I was hoping to stick with perhaps a relay that was all 12v. I have a ton of extra “wall warts” from various computer/networking equpment. I was thinking that maybe I could use one of those to trigger a 12v Relay. Is that something that’s possible? I was also thinking that this would keep all the electronics in the extra box 12v instead of mixing 120v and 12v in the same enclosure.
The problem is you will have 12 volts on the ‘other side’ of the zwave controller you use to switch the transformer. You are not going to be able to communicate with something if you power it on the twelve volt side of the transformer once that device is turned OFF.
The lights are 12Volt but the current on that leg is high (even 3 amps is a lot of current).
You could use a 12volt transformer plugged in (now you have that space problem again) and use to power a zwave low voltage switching device like MimoLite, but you still need another relay that can handle the load current (at up to say, 2.5A; 300W @ 120VAC). That will have to be powered from the active 12V transformer, so it gets a little more complex.
Adding a Relay, you are not really ‘mixing’ voltages as you say, or creating any safety issue (you already have 120VAC and 12VDC present). Plus, it is perfectly normal to have a 120VAC inside an exterior weatherproof enclosure. After all, that is what your zwave wall outlets and switches are ( a 120VAC input relay switching 120VAC). With this setup, you are 120VAC switching 12VDC.
You mentioned above Arduino, which in my opinion is overkill for a single binary switching application (not to mention a lot of time expended gathering all theta together and getting to to work). At the end of the day, you need to switch a 12V circuit with a load up to 3A. So, you’ll need a relay that can handle that voltage and current, and… you will need somewhere to put it!.
Ok. I was just going with the thought that like @RexBecket said, using one with 120v and 12v would be more expensive when we get to the higher amps needed for the 12v side. I figured this would be easily enough solved by just using a 12v relay (that was 100% 12v). The one you linked to seems cheap enough and I may use it, but I am having an issue on figuring out how much amps the 12v will take. I’ve looked over the tech specs, but nothing jumps out at me. It looks like 30-40A, but it was suggested I look at 50A to be safe.
Rex is right, a 50A relay will give you a factor of safety of 2 if you put the entire 300Watts on the sub-circuit @ 25amps on low voltage side
(Sorry Rex, I’m so used to switching high voltage with low voltage…) ???
