???I recently purchased a Vera 3 controller and am completely confused about setting a scene and timer operation. I want the appliance module to turn ON the lamp at sunset and OFF at 11:30 PM. I used the scene tab to set the parameters and also the triggers., but nothing happens. Do I have to include a LUUP program, which I know nothing about. Please HELP!
You need two scenes. The first scene turns On the desired devices at Sunset. The second scene is scheduled to turn Off the desired devices at 11:30pm. These instructions should help you with each scene.
Don’t forget to check the boxes for each and every day that you want that scene, sunset or scheduled, to run.
