Hello,
I’m running the linux firmware and am trying to set the userCode on a Kwikset 888. Using the websocket API I can lock/unlock the lock successfully with:
"method": "hub.item.value.set",
"id": "1604717670278",
"params": {
"_id": "5fa6292700000030860bd20e",
"value": "secured"
But when I try to update the key codes with the following, it doesn’t give an error or update the key codes:
"method":"hub.item.value.set",
"id":"1604717670278",
"params":{
"_id": "5fa6292700000030860bd211",
"valueType": "dictionary",
"elementType": "dictionary.userCode",
"value": {
"1": {
"code": "16345",
"name": "my code"
When I execute the above it does broadcast a bunch of hub.item.updated messages (until the value hits 100):
msg_subclass: 'hub.item.updated',
result: {
_id: '5fa6292600000030860bd209',
deviceCategory: 'door_lock',
deviceId: '5fa6292600000030860bd206',
deviceName: 'SmartCode 888',
deviceSubcategory: '',
notifications: null,
roomName: '',
serviceNotification: false,
syncNotification: false,
userNotification: false,
value: 100,
valueFormatted: '100',
valueType: 'int'
But the key codes don’t update. Any advice on what I should try next?
Thanks!
