Greetings
I live in an apartment that uses Kwikset keys, and I’m looking at upgrading to Z-Wave/Vera.
Since it’s an apartment I’d like to do this without changing the exterior appearance of the door (IE no keypads).
Ideally, I’d use the Kwikset Z-Wave lock system, but only the inside part. I’d install the inside part as normal, but for the key cylinder / outside part, keep the existing hardware.
Does anyone know if this is possible? Or at least, will the Kwikset lock function without the external keypad connected?
Thanks in advance…
