I’m unable to delete PIN codes through Vera. First, I added a code for myself, and when I couldn’t see that it worked, I added the same code again. Clicking “Remove” brings up a window, “Are you sure you want to remove this PIN?” and I confirm… but the deleted PIN remains. I’ve tired deleting both #1 and #2.
