My cost of electricity is $0.068000/KWH when I try to enter my cost into vera plus it says it must be a positive number…
is this a bug?
is this a bug?
how are you getting that number?
what electric company charges such low rates?
It’s right on my bill from Reliant.
2,233 KWH @ $0.068000/kwh = $151.84
After the taxes, fees and other charges ($93.69) my grand total is $245.53 for 2,233 KWH for the month of august (hottest month) coming to a “actual cost” of approx. $0.1099/kwh
so again I ask, can the cost be modified in the system? Otherwise the energy monitoring is useless. Rates here in texas are typically between 6-12 cents per kwh.
thanks
-Matt
[quote=“mnsherick, post:3, topic:194220”]It’s right on my bill from Reliant.
thanks
-Matt[/quote]
those are pretty good rates, i would suggest just putting 7 in the settings box (not point 7 .7, but just the number 7 and nothing else)
user & account info → unit settings → electricity cost.
the dashboard usage appears to be wrong (says i’m spending $87 per hour) but when you go into the energy / current usage page, it’s all right there.
this should be considered a close approximation. not something that you rely on for 100% accuracy.
works for me if i use 0.XXXXXXX. will not work using .XXXXXXX
10c/kwh!!!
FAAAARRRRRKKKK
In australia at the moment i pay around 27c/kWh and they sting us just over $1 a day to have the power connected!!
Europe also controls people’s power usage with extremely high utility costs.
In Mass I pay 0.28 cents per Kwh
pretty good power rates in TX
RVF
