[quote=“cw-kid, post:128, topic:184260”][quote=“cp1983, post:109, topic:184260”][quote=“seanwalter, post:103, topic:184260”]For people on UI7 getting the “Can’t detect device” error…I was also having this problem and solved it pretty simply – after following all instructions in this forum, but with no luck.
I finally decided I had nothing to lose (at 2am…) and noticed in Advanced Settings–>Variables there is a variable called “CommFailure”. I manually changed this from 1 to 0, and now my Kodi Remote is detected.
I did do a couple of other things, but I doubt they are necessary. You can try them if the simple change above doesn’t solve your problem:
Follow all other instructions in the forum to install the plugin correctly and install the addon correctly in Kodi
Upgrade Kodi to 15.0 Isengaard (I was on the 14.2 Helix before)
In Advanced–>Params I filled in the following:
- Added the MAC address for my Kodi box
- Added “Team Kodi” as the manufacturer
- Added “Isengaard” as the model
I am 99% sure all I really had to do was follow the instructions already in the forum and then change the CommFailure variable, but I’ll never know unless someone else in the forum tries to do that and reports back before doing all these other things.
Or maybe sometime this week I’ll set up another instance for the other Kodi box in the house, and report back myself.
ps - many thanks to cw-kid for elaborating the instructions, and for that blog post, which got me thinking more about the effects of the Params and Variables
pps - many many thanks to Ron for an awesome plugin
ppps - on UI7 there is an unlabeled and mostly invisible Mute button…any chance someone can make it more obvious and/or add real volume controls? I am still very much a noob – just opened my first Vera (Edge) this morning.[/quote]
I was also finally able to get rid of the “Can’t detect device” from KODIRemote on UI7. I only changed the CommFailure variable for 0 to 1. No need to change the other parameters.[/quote]
I just installed KodiRemote for the first time on Vera Edge UI7. I am trying to change the CommFailure variable from 1 to 0 however it never seems to keep the change and when I go back in to the Variables tab again its changed back.
I have tried clicking in the field and pressing 0 on keyboard and then tab to come out of the field and it says “Change property command sent”
I’ve also tried ticking the box “switch to input type text” but that doesn’t seem to work either.
How did you change the variable and make it stick?
Also when playing Trailers in the Kodi Apple iTunes Trailers add-on it doesn’t appear to make Vera restart. As I reported it was earlier with my VeraLite UI5.
EDIT: OK maybe it was changing it but I couldn’t see it was, as after refreshing the browser page it now says CommFailure is 0. And after then reloading Vera it now does NOT say “Can’t Detect Device” ;D[/quote]
I’ve been off the forums for awhile, but logged back on today because I’m having the same issues as other people where I can get my VeraEdge to see Kodi for a period of time, but eventually it “loses” the IP address I have manually entered in the Advanced Settings. I have put up with this for a few months now and am finally going to try a few other options, including some of the others mentioned in this thread.
I just don’t want anyone reading the forums thinking the solution I outlined last fall is a permanent solution. It seemed permanent at the time… I’d be interested to revisit if anyone has ideas for making it stick.
