Anyone know if you can use the two systems (OSMC + Openluup) in raspberry?
Enviado desde mi SM-G925F mediante Tapatalk
The only system resource that openLuup uses, apart from a very small amount of memory and CPU, is that it listens on port 3480. Assuming this is not used by Kodi, then it should be fine. I run it on my iMac development system along with lots of other things.
Thanks!!! I try to install it with the guide, another question that i have is how you enter to the interface, by ssh command or simple with a ip as the vera.
Thanks a lot!!!
Yes, it’s the same as Vera, an HTTP request to port 3480:
http://VeraIP:3480/data_request?id=lr_ALTUI_Handler&command=home#
The instructions are in the User Guide. Just make sure you use the :3480 rather than the /port_3480 syntax.
