To everybody , there is a known issue on the version of ALTUI currently deployed. it reports a “Lua Error”.
this is due to an error in the deployment process and the store does not let me fix it right now so I have no mean to fix it for the moment. I asked andrei for help , will keep you informed;
in case you get this error, just take the files from this zip and go to Apps/Develop/Upload files + restart Luup.
Thanks to the help of MCV Andrei & Florin, the issue should be fixed now with v794
you should probably see a lua error one more time but most likely for the last time, one you install that version and let it reload
that is normal error. if you reload , you will get “Controller did not respond” for a little while ( 13-15 times )
clear the error and it should be ok.
otherwise, if you suspect a install issue , try reinstalling by using the following url in your browser http://:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=29588
ignore any errors this page will show you and let time for VERA to reload
