Keep status of switches synced using PLEG?
Hi!
I have a 433Mhz wall switch and power outlet controlling the power to my coffee machine (using a RFXtrx connected to my Vera).
Both the wall switch and the power outlet is shown in Vera as light switches.
To help with the fact 433Mhz devices is not two-way like Z-Wave, I would like PLEG to help me keeping the status off both switches (on or off) synced.
I started setting up four different Inputs, Conditions and Actions but then I though there maybe was a easier way of keeping different switch status synced?
Maybe you can use a virtual switch for this, when a lighton is triggered, your vurtualswitch goes on and vice verca for the off command.
But, be noticed it isnot failsafe!
iPad met behulp van Tapatalk
See:
http://forum.micasaverde.com/index.php/topic,28505.msg204304.html#msg204304
