I noticed this morning there were lights not coming on as they should. Checked UI5 and all but 4 devices have just disappeared from the Vera!
Has anyone else experienced this?
Other than wandering around with the Vera2 on a battery and re-installing all that is missing, is there another solution?
Might have been a corrupted zwave database. What version of UI5 are you on? I have had this happen to my fathers unit (Vera 2) once. Just did a restore of a good last known backup and all was well afterwards.
The last power issue we had was a pair of brief outages about 3 weeks ago, but the Vera appeared to come back from those. I’m wondering if there was a very recent upgrade that might have caused this?
If the Zwave DB did get a bit corrupted, then you may have to restore that at the same time as the backup by checking the “Restore Z-Wave network” box also.
