Hi there,
Would it be possible to have text left aligned in the labels on a tab for the device properties pages.
All text seems to be centered standard.
But the Advanced tab does seem to have the label text left aligned.
It would look more sophisticated if the label text was properly aligned instead of centered.
Any tips?
No, they don’t have any form of “align” represented in the JSON. You can jump to building the entire Tab using Javascript for more advanced L&F.
Here are the reference materials that @futzle RE’d:
http://wiki.micasaverde.com/index.php/Luup_plugin_tabs
http://wiki.micasaverde.com/index.php/Luup_plugins:_Static_JSON_file
along with the Javascript API from @mcvflorin
http://wiki.micasaverde.com/index.php/JavaScript_API
