Hi folks,
thanks for your wonderfull work.
I’ve updated my Veralite to UI7 and installed a new speaker system (dlna compatible of course). Works with uPnp on my phone, WMP on my comp, but can’t see anything on my Vera (DLNA Media Controller installed, plugin version 1.1).
Should I wait for the 1.2 version (couldn’t make it work with manual install, didn’t know how to parameter the new device)?
Thanks in advance
Chris (France)
Is it a DLNA media renderer ?
If you have version 1.1 installed and you want to test version 1.2, just upload through the UI the files of the version 1.2; then clear your WEB browser cache and you are ready.
Open the settings tab/page of your device and push discovery button. If your JBL is a DLNA renderer, it will be discovered. If UPnP discovery is not working and you are using a VeraLite, you can try to install the discovery patch (from the same page). Wait for the Vera reload and try again to discover UPnP renderers.
Tried version 1.2 (installed as you said) and discovery patch. WORKS!!!
You rock!!
Thanks a lot.
