I have a Jasco dimming wall switch set up and used in a scene (if a motion detector detect motion, then turn it on)
It was working find for a year or so, but recently I noticed it no longer works turns on when motion is detected. (I have other lights in the scene, and they work fine. So I know the motion sensor is operating properly. )
BUT: When I go to check the scene, and step through the scene wizard to “Select what each device should do when triggered” If I have the dimming switch selected, I can’t click VALIDATE. If I remove that wall switch and used another device, I can click validate.
I rebuilt the scene…same thing, I can’t hit validate if I have that switch included in the actions.
In the Vera UI, I can control the light (turn on/off and dim) and Vera displays the proper status of the lights in real time. So I know Vera ‘sees’ the switch and can communicate with it.
Odd huh?
Is there an easy way to remove the device from my Vera and re-add it?
Thanks.
P.S. Using a Vera Lite w/ the latest updates applied.
