[quote=“joer., post:5, topic:182549”]So updating for thoroughness…
I wired another Jasco switch and found this dimmer does need the neutral and the hot wires are not reversible (duh).
The Jasco dimmer switches which are requiring a dimmer are:
Jasco 45602W
capabilities: 211,156,0,4,17,1,L,R,B,RS,|38:1,39,112,114,115,119,134,
version: 6,3,40,3,33
The GE dimmer which is working without a neutral:
actually Vera only reads it as: GE/Jasco, no model.
capabilities: 211,156,0,4,17,1,L,R,B,RS,|38:1,39,112,114,134,
version: 6,3,40,3,29
What is also interesting is I checked my Amazon order history and they were all purchased as “GE Z-Wave Wireless Lighting Control Dimmer Switch”.
I can say which is awesome… the JASCO model doesnt have the dimmer ramp issue:
http://forum.micasaverde.com/index.php/topic,13394.15.html[/quote]
Just thought I would clear up some confusion here about the GE/Jasco devices. Jasco Products makes ALL residential products for GE, whether they brand them GE or Jasco, regardless of whether it is a z-wave device or a small appliance. They are the actual manufacturer - but in the case of Z-Wave products, all GE brand products are for sale to consumers whereas the JASCO brand products are only for sale to the service industry, namely contractors such as electricians or integrator’s. Jasco only made this distinction almost 3 years AFTER they started selling the Jasco brand in March of this year, so the market is pretty saturated with both brands. But thats the difference in brands. Now as far as the devices themselves, they are exactly the same except for the color and the packaging. To further confuse the issue, they now have a new model number series that are only for sale to the service industry which ends in xx700 (45712 and 45709 for example). GE z-wave devices are only available in white whereas Jasco z-wave devices are available in white and light almond. Jasco 45712 dimmers are the only change to the devices as they are a 3-wire dimmer as opposed to the 45612 dimmer which is a 2-wire dimmer.
Btw - Jasco just started allowing the sale of the “old” JASCO brand xx600 series switches in light almond direct to consumers again this past week - We have Light Almond switches in stock now if anyone needs them, but it is only for a short time until supplies run out!
[url=http://shop.haworldonline.com/JASCO-Z-Wave-On-Off-Relay-Switch-Model-45609-ZW4001-Lt-Almond-11278.htm]HaWorldOnline.com is for sale | HugeDomains
Bottom line is this, if you are talking about a GE 45609 that is the exact same switch as a JASCO 45609. Check the second number on the back of the switch, they both have the same manufacturer’s model number, ZW4001.
