Hi everyone,
I’m a german developer for Z-Wave Devices and had a little problem with the iVera Software on my iphone.
At the moment I design a new marquee-controller.
The controller works very well with different Z-Wave remotes of different vendors. After I’ve tested this I “put” the marquee-controller into the vera I box (newest firmware).
Now I could controll the device with the buttons on the dashboard. So I could be sure that the hardware is not the problem.
Unfortunately, the vera box has registrate the device as a dimmer device. Because of that I changed these two option…
device_type: urn:schemas-micasaverde-com:device:WindowCovering:1
device_file: D_WindowCovering1.xml
in the advanced device options on the dashboard.
Now I see the little window shutter icon on the dashboard and I got a pull-down menu with open and close - options.
I could open the marquee with the open button and close it with the close button. Only Stop seems not to work.
So far, so good!
Now I tried to controll the device by my iphone and now the problems occurs.
- Open-Button = Close & Close-Button = Open
- At the start-up of the app there is sometimes the open button activated, sometimes stop and sometimes close
- If I press open sometimes the button remais activated and sometimes the stop button get activted. The same with the close-button.
I think that is a problem with the app or have to change some more options?
For the last test I’ve tried to controll the marquee with the mobile web browser of my iphone. That works very fine but the device is a dimmer instead of a window shutter. I got no idea what is wrong there?
I hope you understand my problem (and english ) and could help me with it.
Thanks a lot!
Renz
P.S.: Additional I’ve to say that the marquee normaly opens with a open command and stops with a close command. So you have to click close for two times if you want to close the marquee while it`s running in the open direction.
P.P.S.: Is there a list of the available .xml-files???
