iVera on iOS 4.2.2 issues
Hello!
It seems to be a problem connecting to your system through 3G!
Regards,
Dennis
I’m new to ivera (since i’ve received the new vera2 in remplacment of the old one).
And I can’t loggin into vera using my login/pass from cp.mios.com
I’m not sure if there is a new issue since the last ios, because i’ve installer iVera after the iOs upgrade, but wat I now is that does not work in 3G.
Regards,
Tom
UPDATE: I think i’ve managed to make it working by setting the user and password using wifi (obtained the green dots in each). And then if I shut down wifi (to go back to 3G), it worked.
