3G remote or local.
Advanced, reset all settings, proceed.
Add UN & PW. Choose a Vera, done.
Updating iVera.
System connects and shows devices, Vera Server is busy, Connection error.
Had same issue, rebooted my Vera (per feedback from MCV support) and it’s working again remotely - however not 100% reliably. I was getting the “server busy” message in iVera 100% of the time before reboot, and now I get it about 10% of the time… Prior to this problem I had never had a problem accessing my Vera remotely either via cp.mios.com or via iVera… so there is something going on with the Mios/MCV servers.
As long as you can connect via cp.mios.com, then iVera should be able to connect remotely to your Vera. Same thing with local access, if you can access http://YOUR_VERA_IP from a browser, then iVera should work as well.
Since nothing as changed on the iVera side and rebooting Vera seems to fix the problem, it may be that some modifications on the MCV/mios server sides might be causing iVera some trouble, unfortunately I have not been able to reproduce the issue on my side so far. However, there has been other threads on the forum about remote access issues lately, so that might be related.
If you can reproduce consistently the issue, please send an email to ivera-bug@thinkiwi.com so we can try to debug this issue. Thanks!
