I have been using the Ivera app for a while has worked great but lately when I set the Trane thermostat to cool it will switch to heat mode after a hour or so.
Anyone else having this problem?
Bruce :o
Bruce :o
Does it only happen when using the iVera app, and not when switched through Vera’s Dashboard, or directly on the t-stat?
I experienced a simliar issue with my Trane Thermostat but only when I sent commands using iVera. If I set a new cool set temp in iVera, it would overide it to 65. Because the thermostat works fine from the UI5 interface, I figured it was just a bug with iVera and stopped using it all together.
Hello this only happens when using the Ivera app
Bruce
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
