iTach Flex
Were the iTach Flex drivers and App ever updated? Last time I was following the forums, I finally got it to work using the old drivers, but I could never get the Learn feature to work, so I gave up. Is there a solid solution yet? Thanks in advance.
-A
I got the Itach Flex IR to work following the direction of this post : http://forum.micasaverde.com/index.php/topic,15155.msg137548.html#msg137548
For the Serial connection, I need to write luup code but it is working fine as well.
