Issue when deleting device
In case this wasn’t already known: I unpaired a device from my vera that had variable watches associated with it in a scene set up in AltUI. Once I deleted the device, the scene was no longer editable in AltUI. It still came up in the regular UI.
The way I fixed is was to edit the “VariablesToWatch” field in the AluUI device directly to remove the reference to the deleted device.
Bug I need to fix.
fix will be in v >= 1061
