[quote=“zedrally, post:10, topic:197949”]You need to go back 2 FW versions, there was a Port conflict that Vera created which caused problems with RFXCom.
I’m using a Edge running [size=12px][/size][table][tr][td][size=12px][/size][table][tr][td][size=12px][font=Verdana]1.7.3014[/font][/size][/td][/tr][/table][size=12px][/size][/td][/tr][/table][size=12px][/size][/quote]
Thank you for the suggestion zedrally, unfortunately I believe 1.7.3015 is the Vera Plus version of 1.7.3014 for Vera Edge. Still no go for me with this version. Do you know what firmware (version and type) you are using on the RFXtrx? Maybe this is the culprit?
quote=“tinman, post:11, topic:197949” I don’t think that the RFXCOM app available via the Install Apps page in Vera is supported. It hasn’t been updated in almost 6 years.
(2) The files from trunk – RFXtrx Gateway will work but not with the latest firmware from Vera.
(3) The files in the ZIP file of this post http://forum.micasaverde.com/index.php/topic,52229.0.html are actually updated versions from (2) and will work with the latest firmware.
(4) If you’ve installed (1) you should probably uninstall it.[/quote]
I didn’t use the RFXCOM app from Install Apps, since I already read in the forum that it’s obsolete.
The files from trunk – RFXtrx Gateway (that I refer to as Beta 3) didn’t work at all with 1.7.3015, but partially in latest firmware contrary to the experience from other users here.
Now, the strange thing is that the files in the ZIP file of this post http://forum.micasaverde.com/index.php/topic,52229.0.html (that I refer to as version 1.31) don’t work at all for me, neither on 1.7.3015 or the latest firmware. Actually it seems that with this version it won’t detect any sensors at all and I get a recurring error message in LuaPnp log, for example:
IOPort::Connect connect -1 127.0.0.1:3481
UserData::TempLogFileSystemFailure start 1 <0x77dc1320> followed by a dir listing of files, to me indicating some kind of issue.
02 12/31/17 11:54:59.539 Device_LuaUPnP::CreateServices device 4 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.550 Device_LuaUPnP::CreateServices device 6 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.591 Device_LuaUPnP::CreateServices device 19 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.599 Device_LuaUPnP::CreateServices device 20 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.604 Device_LuaUPnP::CreateServices device 21 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.617 Device_LuaUPnP::CreateServices device 22 doesn’t have interface, using topmost device interface <0x77e8e320>
02 12/31/17 11:54:59.641 Device_Basic::m_eConfigured_set device 1 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.642 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZigbeeDevice1 <0x77e8e320>
02 12/31/17 11:54:59.642 Device_Basic::m_eConfigured_set device 2 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.643 Device_Basic::m_eConfigured_set device 3 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.644 Device_Basic::m_eConfigured_set device 4 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.644 Device_Basic::m_eConfigured_set device 5 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.645 Device_Basic::m_eConfigured_set device 6 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.648 Device_Service::MatchupUpnpServices no upnp service for upnp-rfxcom-com:serviceId:rfxtrx1 <0x77e8e320>
02 12/31/17 11:54:59.648 Device_Service::MatchupUpnpServices no upnp service for urn:rfxcom-com:serviceId:rfxtrx1 <0x77e8e320>
02 12/31/17 11:54:59.648 Device_Basic::m_eConfigured_set device 18 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.649 Device_Service::MatchupUpnpServices no upnp service for upnp-rfxcom-com:serviceId:rfxtrx1 <0x77e8e320>
02 12/31/17 11:54:59.649 Device_Basic::m_eConfigured_set device 19 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.650 Device_Basic::m_eConfigured_set device 20 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.650 Device_Service::MatchupUpnpServices no upnp service for upnp-rfxcom-com:serviceId:rfxtrx1 <0x77e8e320>
02 12/31/17 11:54:59.651 Device_Basic::m_eConfigured_set device 21 was 0 now 0 startup <0x77e8e320>
02 12/31/17 11:54:59.651 Device_Basic::m_eConfigured_set device 22 was 0 now 0 startup <0x77e8e320>
and I have no idea whether this is normal or not or affecting the problem.
Update: after the 20th or so restart of Vera, suddenly it decided to detect all sensors, but I don’t get any readings at all, and I can’t find anything in the logs indicating why. Any ideas?
