I’d like to get a CCTV system outside my home. Is this system any good? Do people have an experience of using it - I’d love to hear their experience? Is it compatible with VeraLite?
I have this kit and like it, however, I cannot connect it to my Vera. you do need to set it up to a router, luckily I had an old router and set that up as a bridge and connected the Foscam unit to it, so I can check via the app or browser and replay anything it may have recorded that set off the motion sensors.
YOu can connect it to your home router, but I have my Vera secure connected to that and wanted the cam system closer to the cams themself. I have the Foscam plugin, it does not see them. If you use IP cam tool, you see it as one IP address even though there are 4 cams.
Personally, Blue Iris is what I use. It supports many, many cameras, and Vera interacts with it. For instance, you can create a virtual motion sensor for each camera, have Vera arm the motion sensors in different modes, and record still and short clips - although I prefer to have Blue Iris do the recording. It doers mean putting software on a computer running 24-7.
