Is there any way to change the Device Icons on the UI7
I have devices that control the pool pump and sprinkler valves
They all show as a light bulb
Is there any way to add some more image and change the image that is shows?
I’m guessing that could could copy the device_file and device_json then tweat the image on these files.
But that would mean that any updates would get lost and I would have to do by hand again the changes
Officially; no.
Your secondary guess is correct.
[quote=“truesolutionsltd, post:1, topic:190876”]I have devices that control the pool pump and sprinkler valves
But that would mean that any updates would get lost and I would have to do by hand again the changes[/quote]
on the UI no, but since most users find that aftermarket apps and such on tablets have alot more options…
Homewave (ios) and Imperihome (andriod) both allow custom icons.
It’s allot of effort when the ui is really about tuning and making changes.
Once the system is working you should forget about the ui and either use an app or even better be completely hands off and automated
[quote=“Chrisfraser05, post:4, topic:190876”]It’s allot of effort when the ui is really about tuning and making changes.
Once the system is working you should forget about the ui and either use an app or even better be completely hands off and automated[/quote]
+1
