Is there a way to see if a device is associated with one or many Reactors?
Somewhat like in Vera where you can go into a device and select ‘Scenes’ and you can see which scenes that device is associated with.
The reason: I’ve been chasing a light that comes on at 8AM every day. I think I’m snow blind at this point looking through all of the Reactors because I’m not finding it. The light doesn’t have any scenes associated with it either so I’m guessing it’s inadvertantly buried in one of the many Reactors I’m running.
I am Running reactor v3.6.
TIA,
-bh
See: Determine where a device is used / referenced? - #3 by rigpapa - Reactor - Ezlo Community
When i generate a logic summary on the parent device i only get the header info for the logic summary. Not that i am having any issues, i was just looking to see all my logic in one summary.
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
   Version: 3.6 config 20070 cdata 20045 ui 20130 pluginDevice 181 LuaXP 1.0.2enh
    System: Vera version 1.7.4970 (7.31) on Sercomm G450 ID 36 (Vera Plus); loadtime 1590797713/1590797742; systemReady 1590797747
       Env: Lua 5.1; JSON dkjson 2.5+LPeg; UnsafeLua=nil/true
Local time: 2020-05-31T21:36:24-0400; DST=1; hometown, North Carolina United States; formats %d/%m/%Y %H:%M:%S
House mode: plugin 1; system 1; tracking on
  Sun data: {"source":"int","civdawn":1590916682,"nautdawn":1590914493,"sunset":1590970366,"nautdusk":1590974332,"stamp":2020152,"latitude":34.753427,"astrodusk":1590976739,"longitude":-74.352989,"civdusk":1590972143,"astrodawn":1590912086,"sunrise":1590918459}
  Geofence: not running
        RS: 1590536954,1590782994,1590789158,1590797654,1590797742
        NS: 0:X,1589067360:U,1590168600:D,1590168905:U,1590181140:D,1590181260:U,1590507960:D,1590508505:U
Sorry! Take the &device= and number off the end of the query string on the URL for now. I’ll hotfix that tomorrow.
Awesome, thanks!
Thanks, this helped greatly !!
