I am having compatibility problems with 1.5.622 I want to revert back to 1.5.408 (I think that is the firmware version veralite arrived with)
How and where can this be done?
Please do not double post. It is considered rude and will not get you an answer faster.
- Garrett
Maybe it is too late, but look at this post: http://forum.micasaverde.com/index.php/topic,22390.msg154794.html#msg154794
We are one firware ahead though…
Yes, you Vera can be downgraded to an earlier firmware version.
The best option would be to raise a support ticket and discuss the reason why you would want to roll back as there have been incremental fixes with different releases and they may have a fix for the issues you have with your current firmware version.
If you decided to proceed yourself, see http://forum.micasaverde.com/index.php/topic,7656.0.html for process and use the link below:
http://download.mios.com/rt3662_betafirmware/rt3662_Luup_ui5-1.5.408-en-mios.squashfs
