I really want to use this plug in but it constantly searches for my vera but never finds it. It never times out, I need to force quit the app and/or clear the app data to try again.
Is there any way to manually configure my vera?
Thanks,
Matt
Thanks,
Matt
I was having the same problem last week. I believe it was caused by a problem with discovery on the micasaverde servers. Problem corrected itself on its own, so I cannot tell you how to manually correct it.
Be sure that you tell AutoVera the correct login information for the current UI version you are using. I believe on another thread you were having issues downgrading to UI5, and that you may still be on UI6. So you would need to specify your UI6 credentials to AutoVera.
On suggestion I have though is to have your local Vera to be onn a fixed IP address. I use the MAC address of the Vera on my router to have the router always assign a specific IP address to Vera. Seemed to speed up the connection to Vera.
