I mostly have Secure Temperature sensors for controlling heat. In a couple of rooms I’ve also installed the Aeon Multisensor 6 to detect motion for turning light on/off.
The Multisensor 6 also have a temperature sensor built in but on the two multisensors I have I see that they report a temperature which are 6-7C higher than what my Secure temperature sensors does in the same room. The only difference is that the Multisensors are located in the roof while the Secure temperature sensors are mounted on the wall about 1.5 meters from the floor.
The difference in the temperature up at the roof can not be that large. Is there anyone else experiencing that the Aeon Multisensor 6 is reporting wrong temperatures?
This doesn’t address your question, but could describe your heat control system? I’ve been trying to understand the hardware configuration used in the many posts that seem to be using Vera as a “virtual thermostat”.
