Is SQ Blaster the only Zwave to IR product out there?
I am in Canada and I am looking for a device that can receive zwave signals and then send IR signals to control A/V devices such as Blurray player, TV, projector, etc…
Is the SQ Blaster and SQ Blaster Plus the only devices that can do so? Are they compatible with VeraLite?
Sq blaster does not do zwave to ir. It does wifi to ir. There is a plug in for the Sq blaster, but requires a little tinkering to set up.
  • Garrett
but is that the only device out there that allows to interact between veralite and ir devices?
No, there are other devices. But they all require some sort of tinkering and time to set up. Have you looked in the AV Control sub-forum?
http://forum.micasaverde.com/index.php/board,24.0.html
There are many topics that are similar to what you are asking.
  • Garrett
Thanks!
