Is it possible to view Z-Wave node map?
Textually? Graphically? Any input on this? Thanks a lot :slight_smile:
If you have a smaller Z-Wave Network, try using @Ap15e’s ADD:
http://forum.micasaverde.com/index.php?topic=5130.0
It uses Google to do the Node graph, which works really nicely on smaller networks… It’s a good way to see how the nodes are connected. It gets busy on mid-size networks, but it’s still workable.
If you have a crazy-large network (@JOD, this is for you!) then it will likely fail due to restrictions placed by Google and/or URL-lengths)
Thank you guessed. I’ll give that a try :slight_smile:
For larger networks you could try installing GraphViz and creating the diagrams on your own:
[tt]http://forum.micasaverde.com/index.php?topic=5130.msg36510#msg36510[/tt]
Thank You Ap15e - I think mine is fairly small, at least for now. However I’ll check this option if needed as well.
