I’ve been using a VeraLite (on UI5) for about a year now, and generally, things have been great. I’ve built my network up to about 25 z-wave devices, and I’m using a bunch of plugins including PLEG, DSC Alarm Panel, MultiSwitch, GCal3, Event Watcher, MultiString, and WakeupRamp. Thanks to everyone on this forum for providing such great resources to help me do this.
Recently, however, my VeraLite has begun randomly locking up and rebooting. For example, activating my “bedtime” scene (which sets about 15 lights and arms the alarm) seems to cause a lockup/reboot before the scene is done executing about 75% of the time. The reboot happens at other times as well (probably 20+ times a day), with no decipherable pattern.
I think that my z-wave network is hosed and that is causing the lockup/reboot problem. Reasons: I have added and removed many z-wave devices; sometimes things got added and deleted properly, other times I had to make multiple attempts to add/remove things to get them to function. My heal report shows zero stars for all devices. My z-wave settings show a last update of 31-DEC-1969. Certain devices continue show up in the UI, despite the fact that they have been deleted. I’ve had to backup/restore the network several times. I used the hack to convert 2.78 to 3.20.
My instinct tells me that its time to wipe my Vera and start over. That will be a painstaking process. So, before I do that, does anybody know if there is a way to rebuild the z-wave network (i.e., exclude everything, wipe out all the z-wave configuration, and re-include everything) other than by doing it manually?
Is there something else I should try first?
