I currently have add a Somfy RTS horizontal blind motor. The blinds are fully operational fully open and close with the remote. I would like to know if any one
has any used the Somfy ZRTSI (1811265) with a Veralite controller to go to a preset position, like on the remote? I want the blinds to open to the preset position from a scene.
Also does any know how to created this Icon I have attached ?
No, only up, down, and stop. I have up set to tilt up all the way, down to tilt down all the way, and stop to make my blinds horizontal. The motors do not know any other positions.
[quote=“ptdsystem, post:1, topic:180126”]I currently have add a Somfy RTS horizontal blind motor. The blinds are fully operational fully open and close with the remote. I would like to know if any one
has any used the Somfy ZRTSI (1811265) with a Veralite controller to go to a preset position, like on the remote? I want the blinds to open to the preset position from a scene. [/quote]
You have to program the Somfy motor to define the preset position. The motor will go to this position when you click the Stop button while the motor is stationary. See the Somfy RTS instructions for how to define the preset position.
Well you appear to have got the images from my [b]WifiRTS[/b] plugin so, yes, I know how I created the icon. If you are using ZRTSI you will get the standard Vera WindowCovering icon, I believe.
