Hi, I purchased a Orbit 6 Station Timer (91876) and 3 Orbit sprinkler valves.
I have connected all and programmed the timer… easy, but when the timer started the valves opened all was well until shut off time came. The valves will not shut off.
I have tested everything many times but the valves will not shut off!
I turned the timer power off and then and only then the valves shut off.
What can be the problem… it appears the timer is keeping the valves open.
[quote=“terryn, post:1, topic:190583”]14/01/16 Australia
