100% for Security Alarm System, no automation at this time. I hope this helps more IRIS users.
So I recently converted from IRIS Lowes Security which we had for four yrs.
Started with IRIS Version 1 and upgraded to Version 2 when it was available. Now that IRIS is shutting down I had to do something and VERA showed to be the most promising.
IRIS V1 devices; Expectations were they would NOT work so I ordered new devices to replace them.
Keypad - mine would not function after Feb 1 2019, so I threw it away.
Door/Window Sensors - I DID get them to register but they show up as a Generic IO device and I can’t get them to do anything. Always says waiting for device configurations.
Motion Sensor - I DID get them to register but they show up as a Generic IO device and I can’t get them to do anything. Always says waiting for device configurations.
NYCE Garage Door Tilt Sensor - I DID get this to register, it shows battery level but always shows “Can’t Detect Device”, and it does not show open/closed when door is operated.
2GIG Glass-break Sensor - I DID get this to register and it goes on/off “Can’t Detect Device”. Push the button and it detects then later is offline.
IRIS V2 devices; Expectations were they “should work” but VERA tech support would not confirm.
KeyPad - I was able to get them to register by using the Centralite device setup.
Door/Window Sensors - I was able to get them to register by using the NYCE door/window device setup, they would not sync any other way.
Motion Sensor - I was able to get them to register by using the NYCE Motion device setup, they would not sync any other way.
VERA Plus - controller
Setup was straight forward and I had only one issues which I found the answer to here. The setup page stalled on updating, had to do over again.
Centralite ZigBee 3-Series Security Keypad - Setup with no issues.
GoControl Z-Wave Thermostat - Setup with no issues.
Philio Door / Window Sensor, Z-Wave Plus - Setup with no issues. I do not like the size of the sensor and the sticky back tape is not holding up.
VistaCam 700 - Indoor HD Wi-Fi Camera - Setup with no issues.
Visonic MCT-340 E Wireless Door Window Temperature Sensor - these were a pain to begin with, could not get them to sync. Finally they synced by using the NYCE door/window device setup. They all showed less then 10% battery life right out of the box. I bought new batteries and they went to 12% battery, not good so far.
Ecolink Zwave Plus Network Security Siren - Setup with no issues, there are FOUR different siren sounds. none of them are great but they work. Two are annoying buzz type, two are beep type.
Now more onto how the system needs to be setup.
I did setup all my Sensors by room or House. At first nothing really worked, this took a while searching the interwebz and trial/error.
You have to create MODES/SCENES for everything.
Key pads - BOTH the IRIS V2 and new Centralite work with only two differences. 1) they do not sound off when door open/close or when the alarm is triggered (had to buy a siren, see above). 2) they work differently IRIS v2 keypad you type in your PIN # first then press home/away, Centralite press home/away then enter PIN#
Setup MODES is pretty easy and very similar to IRIS
Setup SCENES is a work in progress.
Door Chimes (to get back the same user experience) - Add all the sensors, add the actions (siren # on then delay 2sec siren #off), pick when it should be active - this is working great
Alarm! - Add all the sensors, add the actions(siren # on no delay off as i want it to be on till I turn off the alarm), pick when it should be active. - this is not working how I want, well it’s working how I have it setup. Here’s the problem the siren does not turn off, when I enter my PIN # and select HOME. I have to manually go to the device and turn it off. More researh neaded for this to work correctly.
I did add a camera and HVAC controller but have only set them up in a basic setting, since that’s new to me and the alarm function was more critical.
VERA iOS APP (we don’t have any android phones, so can’t comment)
Both my wife and I have different user ID’s and PIN #'s - all is working great.
VERA - local http site
This is better then the iOS app for setup, scenes and more detail into the system.
