i’m thinking of getting a iTach device for my Airconditioners and the AV in the living room.
i have a Samsung TV … and it has only a HDMI and a Source Button on the remote.
butthe selection not starts at the same position. it flips to the next sorce from where you actually are
mean if you on AV1 and press the source button once you get to HDMI1
press it again HDMI2 … so there is no knowing what the IR Code will result in.
since i not have a button on the remote to trigger a certain input … this makes the whole experience much less attractive.
does anyone did face the same issue ? and was able to fix that ?
or maybe there are secret IR codes out there to do trigger directly a input ?
