I when to install a new Vera and IPSerial is now missing from the APP area. This was a great little app, WHY was it removed?
Its the plugin timebomb ticking away
I can not find it either.
Anyone?
I believe the author withdrew the application.
Do we have a work around? This is critical functionality.
If you were using IPSerial to supply a serial connection to a third-party app, you could ask the developer of the app to add support for luup.io.open() directly. That’s what I’ve done for my plugins. Longer term, I think that all plugins will need to do this.
It sounds like you are installing a ‘new’ Vera, does that mean you have a ‘existing’ (second) one?
If so, then the files you need should still be on that other Vera.
Can you not locate/download them and then copy them over to your new Vera?
I’ve been researching which alarm to install and think I’ve decided on NX-8 and the 584 board (or NX-8E). I was going to purchase the Wiznet and use the IPSerial plugin.
But I see the IPSerial plugin is no longer available.
Ms. Futzle: you mention you updated your apps to use luup.io.open() directly. Does that mean I wouldn’t need the IPSerial plugin?
Thank you for any information!
Correct. You use the “Configure” “Connect” tab on the Caddx plugin to specify the IP address and port.
Edit: wrong tab, right idea.
