Good afternoon,
I’ve got some PLEG logic set up to turn off polling when I’m at home, and then turn it on again when an exterior door is open. I do this by set the polling to 0 and muting the device. This greatly reduces my API calls. One issue I’ve run into, is that doing this turns debug_on to the on state on my iPhone. Through a browser, it shows “Undebug” set to off. For devices that aren’t set to debug_on on the app, they also show “Undebug” set to off through the browser.
Is this a known issue? Very confusing.
I’m assuming in debug mode it’s creating more log entries, which can eat up processes in Vera. Unless I specifically want logs, I don’t want to put it into debug mode.
To turn off polling, I use Lua code in the PLEGs:
luup.variable_set(“urn:upnp-org:serviceId:IPhoneLocator1”, “PollingBase”,0, 274)
luup.variable_set(“urn:upnp-org:serviceId:IPhoneLocator1”, “Muted”,1, 274)
return true
To turn it back on:
luup.variable_set(“urn:upnp-org:serviceId:IPhoneLocator1”, “PollingBase”,180, 274)
luup.variable_set(“urn:upnp-org:serviceId:IPhoneLocator1”, “Muted”,0, 274)
luup.variable_set(“urn:upnp-org:serviceId:IPhoneLocator1”, “ForceRefresh”, 274)
return true
