Initial help topic is getting too big, so I am putting a version change log here.
Latest version doc : [url=http://forum.micasaverde.com/index.php/topic,16907.msg130221.html#msg130221]http://forum.micasaverde.com/index.php/topic,16907.msg130221.html#msg130221[/url]
Change Log
Version 2.48
[ul][li]Google Map API key support[/li][/ul]
Version 2.42
[ul][li]Fix for json decoder, use dkjson 1.2[/li][/ul]
Version 2.41
[ul][li]Fix for iCloud’s protocol change to get location information. bonus: it saves one web service call ![/li][/ul]
Version 2.40
[ul][li]ICLoudName variable & ability to change device name attribute[/li][/ul]
Version 2.39
[ul][li]fix for phone names which include - or other lua pattern special characters [/li]
[li]fix for openluup [/li][/ul]
Version 2.32
[ul][li]fix for phone names which include ( ). ( escaping characters in pattern string ) [/li][/ul]
Version 2.31
[ul][li]n+1 tentative to fix the special character issue in password.[/li][/ul]
Version 2.3
[ul][li]use UI7 Top bar for plugin setting pages[/li]
[li]Fix error when google matrix api is not returning a valid route ( in driving, cycling modes … ) [/li]
[li]Fix infinite error string concatenation when error happens in the plugin[/li]
[li]url encode pwd to try to support special char in pwd[/li]
[li]remove forceReresh UPNP action return parameter (to remove a warning in logs)[/li]
[li]workaround so that UI7 does not remove a empty variable ( PollingMap ) ![/li][/ul]
Version 2.1
[ul][li]Does not force a refresh when unMute is called if the phone was already unMuted[/li]
[li]cosmetics UI7[/li]
[li]use of Jobs instead of Runs to avoid Luup deadlock & restarts[/li]
[li]Compat fix for AltUI plugin[/li][/ul]
Version 1.98 ( was 1.97 beta )
[ul][li]“CurLat CurLong” : Add these 2 in the servicestatevariable so they are reported in the device status xml output page of vera[/li]
[li]“RootPrefix” : new variable to change prefix of root device name, defaults to (*)[/li][/ul]
Version 1.96
Direct Install link: :3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=4686&Version=25446
[ul][li]“LocationExtraInfo” : new variable, cf doc[/li]
[li]taking into account the accuracy reported by iCloud in the “Present” state calculation[/li]
[li]fix for google map javascript not properly displaying twice on UI7[/li]
[li]Adding scene tab[/li][/ul]
Version 1.95
[ul][li]“HouseModeActor” : new variable, cf doc[/li]
[li]automatic HouseMode determination[/li][/ul]
Version 1.93
[ul][li]initial UI7 support[/li][/ul]
