PS, I’ve also added an automatic Vacation mode which triggers when we are both more than 100kms from home - this also mutes location polling and I have a Reator sensor which will re-enable location polling if it detects the Garage door change from Closed to Open while Vacation mode is active.
I think I have about 36 reactor sensors atm - I think they are like Pringles, once you start you can’t stop!
Thanks for sharing this. Right now using reactor to trigger when the phone go home / away seems to be working rather well.
Except that the mobile Beta app expired on the way home today, so that didn’t work! And I’m going to be rather a long way outside my geofence for a while so much testing will be dependent on the resident
Does this mean anyone who is able to open your garage will disarm your whole house? Or you have no alert/Siren upon Garage opening and house mode = Away/Vacation?
1/ if we aren’t home and the garage opens and we arent within 100m of the house, Vera does not switch to home mode. The garage state changing is merely a trigger to check our phone locations.
2/ we also have a monitored alarm system that isn’t tied to our Vera as a backup.
