Since updating to the latest firmware on my Vera edge I can not seem to configure iPhone locator plugin as it does not hold any devices in the settings/iCloud section. It will present my device correctly but when I add them there is not ?save?button so I go back to the ?control? tab and select ?save changes? then go back to check and all selected devices are removed
I have observed no issues yet other than this issue and edge still reports that I am using the latest fw
Edit:
I have observed that all Aeon smart switch 6 have to be re added and no scene involves switch are working
I have observed no issues yet other than this issue and edge still reports that I am using the latest fw [/quote]
we will see what VERA does with this firmware and if they release a quick fix
can you please share a screen that shows the issue you have, also please enable DEBUG mode in iPhone device plugin settings, then reload Luup, then try to reproduce your issues/. once that done, please share the log file and restore normal mode in iPhone device plugin settings
can you please share a screen that shows the issue you have, also please enable DEBUG mode in iPhone device plugin settings, then reload Luup, then try to reproduce your issues/. once that done, please share the log file and restore normal mode in iPhone device plugin settings[/quote]
I have uninstalled the iPhone app and it will not show up after reinstalling. When I have time I will manually go through file system and cleanup to see if it helps
